Lines render with Gaps
Key: GEOS-4407
URL: http://jira.codehaus.org/browse/GEOS-4407
Project: GeoServer
Issue Type: Bug
Components: Oracle
Affects Versions: 2.1-RC2, 2.1-RC1
Environment: Windows Server 2003 & Windows 7
Reporter: Steve Way
Assignee: Andrea Aime
Fix For: 2.1.x
Attachments: LineData.7z
My Line data for one of my products is rendering with gaps between them (noticeable with the blue motorways), and also in some cases not rendering any lines at all (the red lines!).
If all other line styles are removed from the SLD then they render fine.
Attached is a zip with the line data in Oracle SQL loader format, the SLD and example screen shots of the error and expected output.
This is taken at a scale of 1:210,000
SRS = EPSG:27700
(x,y) = 571470,157425
