[Geoserver-devel] [jira] Created: (GEOS-4416) Error when deleting PostGIS Store with previously deleted Layers
                 Key: GEOS-4416
                 URL: http://jira.codehaus.org/browse/GEOS-4416
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-RC2
         Environment: Linux geoserver 2.6.32-29-server #58-Ubuntu SMP Fri Feb 11 21:06:51 UTC 2011 x86_64 GNU/Linux
Sun Microsystems Inc.: 1.6.0_20 (OpenJDK 64-Bit Server VM)
            Reporter: Gerardo Lisboa
            Assignee: Andrea Aime
steps:
1) delete 1 layer
(result: layer is deleted from layers list but it is still marked Published on the store's list)
2) delete the store that contained that layer
After restarting the tomcat instance, the layer is no longer marked Published and the store can be deleted with no problems.
No problem if deleting store before deleting layer (layer is correctly deleted).
Java.lang.IllegalArgumentException: Unable to delete non-empty store.
  at org.geoserver.catalog.impl.CatalogImpl.remove(CatalogImpl.java:163)
  at org.geoserver.security.SecureCatalogImpl.remove(SecureCatalogImpl.java:1019)
  at org.geoserver.catalog.CascadeDeleteVisitor.visitStore(CascadeDeleteVisitor.java:71)
  at org.geoserver.catalog.CascadeDeleteVisitor.visit(CascadeDeleteVisitor.java:75)
  at org.geoserver.catalog.impl.DataStoreInfoImpl.accept(DataStoreInfoImpl.java:41)
  at sun.reflect.GeneratedMethodAccessor311.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Method.java:616)
  at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
  at $Proxy13.accept(Unknown Source)
  at org.geoserver.web.data.SelectionRemovalLink$1.onSubmit(SelectionRemovalLink.java:65)
  at org.geoserver.web.wicket.GeoServerDialog$4.onSubmit(GeoServerDialog.java:139)
  at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
  at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
  at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
  at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
  at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
  at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
  at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
  at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
  at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
  at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
  at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
  at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
  at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
  at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
  at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
  at java.lang.Thread.run(Thread.java:636)
