[Geoserver-devel] [jira] Created: (GEOS-4440) GeoServer fails to load raster for one layer from file system but works with mounted volume
                 Key: GEOS-4440
                 URL: http://jira.codehaus.org/browse/GEOS-4440
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.7.6
         Environment: Redhat linux or Ubuntu 10.04
Java 1.6 64-bit with jai 64-bit
            Reporter: Suneet Kamath
            Assignee: Andrea Aime
            Priority: Blocker
Have multiple layers configured in GeoServer using the 1.7.6 installation as detailed here
http://osgbwebmaptools.sourceforge.net/OSGBWebMapTools.html
The following errors are seen in the log below
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Reading mosaic from file:/media/OpenData/OSGBWebMapTools/Data/Tiles/StreetView/StreetView.shp
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Highest res 1.0 1.0
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.log(Log4JLogger.java:122) - Adjusted Requested Envelope = ReferencedEnvelope[531000.0 : 531750.0, 180000.0 : 180750.0]
Requested raster dimension = java.awt.Rectangle[x=0,y=0,width=750,height=750]
Corresponding raster source region = java.awt.Rectangle[x=0,y=0,width=750,height=750]
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Loading level 0 with subsampling factors 1 1
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Index does not need to be created...
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - About to read image number 0
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Trying to resolve path:
type:RELATIVE
parentLocation:/media/OpenData/OSGBWebMapTools/Data/Tiles/StreetView
22 Mar 18:00:02 DEBUG [imagemosaic.ImageMosaicUtils] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Checking file:/media/OpenData/OSGBWebMapTools/Data/Tiles/StreetView/
canRead:false
isHidden:false
isFilefalse
canWritefalse
22 Mar 18:00:02 INFO [gce.imagemosai] org.geotools.util.logging.Log4JLogger.info(Log4JLogger.java:135) - Unable to read image for file /media/OpenData/OSGBWebMapTools/Data/Tiles/StreetView/TQ37NW.tif
type:RELATIVE
canRead:false
isHidden:false
isFilefalse
canWritefalse
22 Mar 18:00:02 INFO [gce.imagemosai] org.geotools.util.logging.Log4JLogger.info(Log4JLogger.java:135) - Unable to read image for file /media/OpenData/OSGBWebMapTools/Data/Tiles/StreetView/TQ38SW.tif
22 Mar 18:00:02 DEBUG [gce.imagemosai] org.geotools.util.logging.Log4JLogger.log(Log4JLogger.java:122) - Unable to load any granule
22 Mar 18:00:02 DEBUG [geotools.rendering] org.geotools.util.logging.Log4JLogger.fine(Log4JLogger.java:137) - Drawing coverage GridCoverage2D["StreetView", GeneralEnvelope[(531000.0, 180000.0), (531750.0, 180750.0)], DefaultProjectedCRS["Transverse_Mercator"]]
â Image=RenderedOp["Constant"] as views [NATIVE, PACKED, RENDERED, GEOPHYSICS, PHOTOGRAPHIC]
My initials thoughts was that the error might be related to the number of files for that layer being above 10000 and around 45 GB. as discussed in GEOS-3548. However, when mountng a network data store, the tiles are rendered.
This might be a problem with geotools imagemosaic as indicated in the logs, however I thought I would post the question here first.
Please note that we do have plans to switch to a later version of GeoServer but for now the plan is to use the exact version as documented in the link above.
Regards
Suneet
