[Geoserver-devel] [jira] Created: (GEOS-4452) Error viewing wms layer: 2 SRIDs in same layer ( not true) ) error: Operation on two geometries with different SRIDs
                 Key: GEOS-4452
                 URL: http://jira.codehaus.org/browse/GEOS-4452
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
         Environment: Error viewing wms layer: 2 SRIDs in same layer ( not true) ) error: operation on two geometries with different SRIDs
            Reporter: Marc Benito
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: error_snapshot.JPG
Error viewing wms layer in geoserver.
I create 2 differents datastores (postGis stores) pointing to the same machine ( ex: Server1) accessing to different databases but with the same schema and same table but with different SRIDs
Ex:
Server1 ( postgres) --> databaseBarcelona --> map.limit_line --> srid ( the_geom ) == 23031
Server2 ( postgres) --> databaseMadrid --> map.limit_line --> srid ( the_geom ) == 900913
When i acces to the first, the wms layer runs OK.
When i acces to the second. the wms layers report an ERROR:
   org.postgresql.util.PSQLException: ERROR: Operation on two geometries with different SRIDs
  at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
  at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
  at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
  at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
  at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
  at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
  at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
  at org.geotools.jdbc.JDBCFeatureReader.<init>(JDBCFeatureReader.java:147)
  at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:557)
  ... 149 more
I Reproduce this error in 2 different enviroments:
  - with the build 2.1 of 30-03-2011 --> 2.1-SNAPSHOT -->Subversion Revision: 15612
  - with an old 2.1 build ( 2 months ago).
In both cases occurs the same.
I Founf a solution:
Change the name of the table:
When i changed the name of the table the second layers runs OK.
