[Geoserver-devel] [jira] Created: (GEOS-4453) Documentation of numberFormat filter function has arguments reversed.
                 Key: GEOS-4453
                 URL: http://jira.codehaus.org/browse/GEOS-4453
             Project: GeoServer
          Issue Type: Improvement
          Components: Documentation
    Affects Versions: 2.1-RC1
            Reporter: Clive Butler
            Assignee: Andrea Aime
            Priority: Trivial
Documentation for the numberFormat filter function has the arguments reversed (the format should be listed as the first argument if it is to agree with the implementation).
The ordering of XML elements is actually unspecified in the documentation, but the obvious interpretation is that the first named parameter corresponds to the first element.
