[Geoserver-devel] [jira] Created: (GEOS-4469) Customize BalloonStyle in KML output (aka Remove "Directions To Here / From Here" in Google Earth)
                 Key: GEOS-4469
                 URL: http://jira.codehaus.org/browse/GEOS-4469
             Project: GeoServer
          Issue Type: Improvement
          Components: Google Earth KML Output
    Affects Versions: 2.1-RC4
         Environment: Google Earth
            Reporter: Mike Pumphrey
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 2.1.x
KML output on a points layer generates a footer in the placemark that says "Directions: To Here / From here" In KML, this is customized in the BalloonStyle tag, but there doesn't appear to be a way to customize this (i.e. remove it) from within GeoServer.
The only reference to BalloonStyle I could find in the code was here:
  http://svn.codehaus.org/geoserver/trunk/src/wms/src/main/java/org/geoserver/kml/KMLMapTransformer.java
More info about BalloonStyle:
  http://code.google.com/apis/kml/documentation/kmlreference.html#balloonstyle
