Styles confirm remove panel fails with core styles (line, point, etc)
Key: GEOS-4470
URL: http://jira.codehaus.org/browse/GEOS-4470
Project: GeoServer
Issue Type: Bug
Components: Wicket UI
Affects Versions: 2.1-RC4
Reporter: Eric Lawrey
Assignee: Andrea Aime
Priority: Minor
When attempting to delete one of the core style (line, point, polygon, raster) the Confirm object removal panel displays a server error (Oops, something went wrong...) rather than a useful error message.
Ideally if these styles can not be deleted then their check box in the Styles page should be disabled.
To reproduce:
Go to Styles
Select raster
Click on "Removed selected style(s)"
This results in the following trace:
org.apache.wicket.WicketRuntimeException: Property 'ConfirmRemovalPanel.notRemovedObject' not found in property files. Markup: [markup = jar:file:/home/reefatlas/ningaloo_site/geoserver2/tomcat/webapps/geoserver2/WEB-INF/lib/web-core-2.1-RC4.jar!/org/geoserver/web/data/ConfirmRemovalPanel.html
<html>
<body>
<wicket:panel>
<div wicket:id="rootObjects">
<h3>
<wicket:message key="ConfirmRemovalPanel.aboutRemove">About to remove</wicket:message>: <span wicket:id="rootObjectNames"></span>
</h3>
</div>
<div wicket:id="notRemovedObjects">
<wicket:message key="ConfirmRemovalPanel.notRemovedObject">The following objects could not be removed:</wicket:message>
<ul class="plain-ul">
<li wicket:id="notRemovedList"><span wicket:id="name"></span>: <span wicket:id="reason"></span></li>
</ul>
</div>
<div wicket:id="removedObjects">
<wicket:message key="ConfirmRemovalPanel.removedObjects">The following objects will be removed</wicket:message>:
<li wicket:id="workspacesRemoved"><wicket:message key="ConfirmRemovalPanel.workspaces"/>: <span wicket:id="workspaces"></span></li>
<li wicket:id="storesRemoved" class="plain-li"><wicket:message key="ConfirmRemovalPanel.stores"/>:
<span wicket:id="stores"></span></li>
<li wicket:id="layersRemoved"><wicket:message key="ConfirmRemovalPanel.layers"/>:
<span wicket:id="layers"></span></li>
<li wicket:id="groupsRemoved"><wicket:message key="ConfirmRemovalPanel.groups"/>:
<span wicket:id="groups"></span></li>
</ul>
</div>
<div wicket:id="modifiedObjects">
<wicket:message key="ConfirmRemovalPanel.modifiedObjects">The following objects will be modified as a result</wicket:message>:
<li wicket:id="layersModified"><wicket:message key="ConfirmRemovalPanel.layers"/>:
<li wicket:id="groupsModified"><wicket:message key="ConfirmRemovalPanel.groups"/>:
</ul>
</div>
</wicket:panel>
</body>
</html>, index = 18, current = [Raw markup]]
at org.apache.wicket.markup.resolver.WicketMessageResolver$MessageContainer.onComponentTagBody(WicketMessageResolver.java:217)
at org.apache.wicket.Component.renderComponent(Component.java:2686)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1538)
at org.apache.wicket.Component.render(Component.java:2517)
at org.apache.wicket.MarkupContainer.autoAdd(MarkupContainer.java:229)
at org.apache.wicket.markup.resolver.WicketMessageResolver.resolve(WicketMessageResolver.java:148)
at org.apache.wicket.markup.resolver.ComponentResolvers.resolve(ComponentResolvers.java:81)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1444)
at org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1603)
at org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1527)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1440)
at org.apache.wicket.MarkupContainer.renderAssociatedMarkup(MarkupContainer.java:696)
at org.apache.wicket.markup.html.panel.Panel.onComponentTagBody(Panel.java:114)
at org.apache.wicket.markup.html.form.Form.onComponentTagBody(Form.java:1995)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1554)
at org.apache.wicket.Page.onRender(Page.java:1575)
at org.apache.wicket.Page.renderPage(Page.java:913)
at org.apache.wicket.request.target.component.PageRequestTarget.respond(PageRequestTarget.java:63)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Thread.java:619)
