[Geoserver-devel] [jira] Created: (GEOS-4471) enabled property for LayerGroupInfo
                 Key: GEOS-4471
                 URL: http://jira.codehaus.org/browse/GEOS-4471
             Project: GeoServer
          Issue Type: New Feature
          Components: Configuration, Wicket UI
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.2.x
{{LayerGroupInfo}}s can't be enabled/disabled as they don't have an enabled property like {{LayerInfo}} has.
Moreover, it would need a derived {{enabled()}} property just like {{LayerInfo}} that in turn defers to all its {{LayerInfo.enabled()}}.
Otherwise it is not possible to temporarily disable a LayerGroup from being accessed, nor to know beforehand if it's gonna fail because of some of it's layer infos is misconfigured.
