[Geoserver-devel] [jira] Created: (GEOS-4495) CatalogValidators running but failures do not result in any action
                 Key: GEOS-4495
                 URL: http://jira.codehaus.org/browse/GEOS-4495
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1-RC4
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
CatalogValidators are run by the catalog code. However the postValidate(info, isNew) method returns a list of errors (instead of throwing an exception) that the catalog is not using, resulting in the validation code to fail silently.
For example, try to setup a cascaded wms layer. The WMSValidator will not recognize it and will throw an exception (so that validation needs an update), but nothing will really happen
