Error running cache diskquota enforcement task java.lang.NullPointerException
Key: GEOS-4499
URL: http://jira.codehaus.org/browse/GEOS-4499
Project: GeoServer
Issue Type: Bug
Components: GWC
Environment: ubuntu1 10.04
Reporter: mickae1
Assignee: Andrea Aime
Fix For: 2.1.x
Hello, on this version http://gridlock.opengeo.org/geoserver/2.1.x/geoserver-2.1.x-2011-04-20-war.zip
I got this error on my log :
2011-04-20 15:39:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
at org.geowebcache.layer.TileLayerDispatcher.checkConfigurationLoaded(TileLayerDispatcher.java:116)
at org.geowebcache.layer.TileLayerDispatcher.getLayers(TileLayerDispatcher.java:153)
at org.geowebcache.layer.TileLayerDispatcher.getLayerNames(TileLayerDispatcher.java:339)
at org.geowebcache.diskquota.DiskQuotaMonitor.getLayerNames(DiskQuotaMonitor.java:357)
at org.geowebcache.diskquota.CacheCleanerTask.innerRun(CacheCleanerTask.java:104)
at org.geowebcache.diskquota.CacheCleanerTask.run(CacheCleanerTask.java:84)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:317)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:150)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(ScheduledThreadPoolExecutor.java:98)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:204)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
2011-04-20 15:39:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:39:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:40:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:40:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:40:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:40:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:40:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:40:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:41:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:41:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:41:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:41:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:41:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:41:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:42:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:42:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:42:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:42:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:42:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:42:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:43:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:43:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:43:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:43:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:43:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:43:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:44:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:44:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:44:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:44:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:44:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:44:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:45:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:45:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:45:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:45:39,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:45:49,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:45:59,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:46:09,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:46:19,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:46:29,931 ERROR [diskquota.CacheCleanerTask] - Error running cache diskquota enforcement task
2011-04-20 15:46:34,039 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down...
2011-04-20 15:46:34,040 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor...
2011-04-20 15:46:34,040 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor...
2011-04-20 15:46:34,040 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor...
2011-04-20 15:46:34,040 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2011-04-20 15:46:34,040 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'DiskQuotaMonitor': java.lang.NullPointerException
2011-04-20 15:46:34,041 INFO [georss.GeoRSSPoller] - destroy() invoked
2011-04-20 15:46:34,041 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2011-04-20 15:46:34,041 INFO [storage.BDBQuotaStore] - Requesting to close quota store...
2011-04-20 15:46:34,072 INFO [storage.BDBQuotaStore] - Quota store closed.
2011-04-20 15:46:34,072 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks...
2011-04-20 15:46:34,072 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2011-04-20 15:46:34,073 INFO [storage.StorageBroker] - Destroying StorageBroker
2011-04-20 15:46:34,075 ERROR [jdbc.JDBCMBWrapper] - Couldn't obtain JDBC Connection to perform database shut down
org.h2.jdbc.JdbcSQLException: Database is already closed (to disable automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-119]
at org.h2.message.Message.getSQLException(Message.java:106)
at org.h2.message.Message.getSQLException(Message.java:117)
at org.h2.message.Message.getSQLException(Message.java:76)
at org.h2.message.Message.getSQLException(Message.java:152)
at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1328)
at org.h2.jdbcx.JdbcXAConnection$PooledJdbcConnection.checkClosed(JdbcXAConnection.java:505)
at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1303)
at org.h2.jdbc.JdbcConnection.setAutoCommit(JdbcConnection.java:354)
at org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.getConnection(JDBCMBWrapper.java:183)
at org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.destroy(JDBCMBWrapper.java:618)
at org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend.destroy(JDBCMetaBackend.java:274)
at org.springframework.beans.factory.support.DisposableBeanAdapter.invokeCustomDestroyMethod(DisposableBeanAdapter.java:208)
at org.springframework.beans.factory.support.DisposableBeanAdapter.destroy(DisposableBeanAdapter.java:165)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroyBean(DefaultSingletonBeanRegistry.java:456)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingleton(DefaultSingletonBeanRegistry.java:434)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons(DefaultSingletonBeanRegistry.java:407)
at org.springframework.context.support.AbstractApplicationContext.destroyBeans(AbstractApplicationContext.java:854)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:832)
at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:795)
at org.springframework.web.context.ContextLoader.closeWebApplicationContext(ContextLoader.java:361)
at org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:70)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4011)
at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4615)
at org.apache.catalina.core.ContainerBase.removeChild(ContainerBase.java:924)
at org.apache.catalina.startup.HostConfig.undeployApps(HostConfig.java:1319)
at org.apache.catalina.startup.HostConfig.stop(HostConfig.java:1290)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:323)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.stop(ContainerBase.java:1086)
at org.apache.catalina.core.ContainerBase.stop(ContainerBase.java:1098)
at org.apache.catalina.core.StandardEngine.stop(StandardEngine.java:448)
at org.apache.catalina.core.StandardService.stop(StandardService.java:584)
at org.apache.catalina.core.StandardServer.stop(StandardServer.java:744)
at org.apache.catalina.startup.Catalina.stop(Catalina.java:643)
at org.apache.catalina.startup.Catalina$CatalinaShutdownHook.run(Catalina.java:687)
2011-04-20 15:46:35,729 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-1c9cbf52:12e7c741213:-7ffe'
2011-04-20 15:46:35,730 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-115291c:12ed3bfaffc:-7fed'
2011-04-20 15:46:35,730 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-115291c:12ed3bfaffc:-7fe2'
2011-04-20 15:46:35,730 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--2c83785f:12ea1928b0b:-7ff3'
2011-04-20 15:46:43,863 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /home/mickael/geoserver_data
2011-04-20 15:46:43,984 INFO [org.geoserver] - Loaded style 'dem'
2011-04-20 15:46:43,985 INFO [org.geoserver] - Loaded style 'restricted'
2011-04-20 15:46:43,986 INFO [org.geoserver] - Loaded style 'giant_polygon'
2011-04-20 15:46:43,986 INFO [org.geoserver] - Loaded style 'grass'
2011-04-20 15:46:43,987 INFO [org.geoserver] - Loaded style 'point'
2011-04-20 15:46:43,987 INFO [org.geoserver] - Loaded style 'rain'
2011-04-20 15:46:43,988 INFO [org.geoserver] - Loaded style 'capitals'
2011-04-20 15:46:43,990 INFO [org.geoserver] - Loaded style 'simple_roads'
2011-04-20 15:46:43,991 INFO [org.geoserver] - Loaded style 'ta_lu'
2011-04-20 15:46:43,991 INFO [org.geoserver] - Loaded style 'green'
2011-04-20 15:46:43,992 INFO [org.geoserver] - Loaded style 'ta_02_03_04'
2011-04-20 15:46:43,992 INFO [org.geoserver] - Loaded style 'line'
2011-04-20 15:46:43,993 INFO [org.geoserver] - Loaded style 'pophatch'
2011-04-20 15:46:43,994 INFO [org.geoserver] - Loaded style 'ta_wl'
2011-04-20 15:46:43,994 INFO [org.geoserver] - Loaded style 'poly_landmarks'
2011-04-20 15:46:43,996 INFO [org.geoserver] - Loaded style 'lmj'
2011-04-20 15:46:43,997 INFO [org.geoserver] - Loaded style 'ta_wa'
2011-04-20 15:46:43,997 INFO [org.geoserver] - Loaded style 'poi'
2011-04-20 15:46:43,998 INFO [org.geoserver] - Loaded style 'tiger_roads'
2011-04-20 15:46:43,998 INFO [org.geoserver] - Loaded style 'cite_lakes'
2011-04-20 15:46:43,999 INFO [org.geoserver] - Loaded style 'ta_a8'
2011-04-20 15:46:44,000 INFO [org.geoserver] - Loaded style 'ta_05_06_07'
2011-04-20 15:46:44,001 INFO [org.geoserver] - Loaded style 'ta_00_01'
2011-04-20 15:46:44,001 INFO [org.geoserver] - Loaded style 'ta_08'
2011-04-20 15:46:44,002 INFO [org.geoserver] - Loaded style 'population'
2011-04-20 15:46:44,002 INFO [org.geoserver] - Loaded style 'simple_streams'
2011-04-20 15:46:44,003 INFO [org.geoserver] - Loaded style 'raster'
2011-04-20 15:46:44,003 INFO [org.geoserver] - Loaded style 'polygon'
2011-04-20 15:46:44,004 INFO [org.geoserver] - Loaded style 'burg'
2011-04-20 15:46:44,005 INFO [org.geoserver] - Loaded default workspace test
2011-04-20 15:46:44,012 INFO [org.geoserver] - Loaded workspace 'test'
2011-04-20 15:46:44,014 INFO [org.geoserver] - Loaded workspace 'LMJ'
2011-04-20 15:46:44,019 INFO [org.geoserver] - Loaded store 'multinet', enabled
2011-04-20 15:46:44,025 INFO [org.geoserver] - Loaded data store 'multinet'
2011-04-20 15:46:45,665 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2011-04-20 15:46:45,935 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_7', enabled
2011-04-20 15:46:45,946 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:45,965 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_7'
2011-04-20 15:46:45,972 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_3', enabled
2011-04-20 15:46:45,972 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:45,974 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_3'
2011-04-20 15:46:45,980 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_5', enabled
2011-04-20 15:46:45,981 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:45,982 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_5'
2011-04-20 15:46:45,987 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_8', enabled
2011-04-20 15:46:45,988 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:45,990 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_8'
2011-04-20 15:46:45,995 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_4', enabled
2011-04-20 15:46:45,996 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:45,997 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_4'
2011-04-20 15:46:46,003 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_6', enabled
2011-04-20 15:46:46,003 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:46,005 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_6'
2011-04-20 15:46:46,010 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_1', enabled
2011-04-20 15:46:46,011 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:46,012 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_1'
2011-04-20 15:46:46,018 INFO [org.geoserver] - Loaded feature type 'fraf10___________nw_2', enabled
2011-04-20 15:46:46,018 INFO [org.geoserver] - Loaded feature type 'multinet'
2011-04-20 15:46:46,021 INFO [org.geoserver] - Loaded layer 'fraf10___________nw_2'
2011-04-20 15:46:46,023 INFO [org.geoserver] - Loaded store 'gis', enabled
2011-04-20 15:46:46,024 INFO [org.geoserver] - Loaded data store 'gis'
2011-04-20 15:46:46,269 INFO [org.geoserver] - Loaded feature type 'toto', enabled
2011-04-20 15:46:46,269 INFO [org.geoserver] - Loaded feature type 'gis'
2011-04-20 15:46:46,271 INFO [org.geoserver] - Loaded layer 'toto'
2011-04-20 15:46:46,272 INFO [org.geoserver] - Loaded store 'TeleAtlas', enabled
2011-04-20 15:46:46,272 INFO [org.geoserver] - Loaded data store 'TeleAtlas'
2011-04-20 15:46:46,297 INFO [org.geoserver] - Loaded store 'test_geoserver', enabled
2011-04-20 15:46:46,298 INFO [org.geoserver] - Loaded data store 'test_geoserver'
2011-04-20 15:46:46,305 INFO [org.geoserver] - Loaded layer group 'France'
2011-04-20 15:46:46,414 INFO [org.geoserver] - Loaded service 'wcs', enabled
2011-04-20 15:46:46,442 INFO [org.geoserver] - Loaded service 'wfs', enabled
2011-04-20 15:46:46,474 INFO [org.geoserver] - Loaded service 'wms', enabled
2011-04-20 15:46:46,520 INFO [storage.DefaultStorageFinder] - *******************************************************************************************************************************
2011-04-20 15:46:46,520 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to /home/mickael/geoserver_data, using it as the default prefix. ***
2011-04-20 15:46:46,926 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
2011-04-20 15:46:46,959 INFO [config.XMLConfiguration] - Failed to find geowebcache.xml. This is not a problem unless you are trying to use a custom XML configuration file.
2011-04-20 15:46:47,212 INFO [layer.TileLayerDispatcher] - Adding layers from GeoServer Catalog Configuration
2011-04-20 15:46:47,212 INFO [layer.TileLayerDispatcher] - Adding: France
2011-04-20 15:46:47,212 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_6
2011-04-20 15:46:47,212 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_5
2011-04-20 15:46:47,212 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_4
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_3
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding: test:toto
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_2
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_1
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_8
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding: test:fraf10___________nw_7
2011-04-20 15:46:47,213 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
2011-04-20 15:46:47,213 INFO [config.XMLConfiguration] - Found configuration file in /var/lib/tomcat6/webapps/geoserver/../resources
2011-04-20 15:46:47,213 INFO [layer.TileLayerDispatcher] - Adding layers from /var/lib/tomcat6/webapps/geoserver/../resources
2011-04-20 15:46:47,213 ERROR [layer.TileLayerDispatcher] - Configuration /var/lib/tomcat6/webapps/geoserver/../resources contained no layers.
2011-04-20 15:46:47,214 ERROR [layer.TileLayerDispatcher] - Error reading service information from /var/lib/tomcat6/webapps/geoserver/../resources: Error parsing file /var/lib/tomcat6/webapps/geoserver/../resources/geowebcache.xml
2011-04-20 15:46:47,215 INFO [layer.TileLayerDispatcher] - ConfigurationLoader completed
2011-04-20 15:46:47,266 WARN [storage.EntityStoreBuilder] - Neither disk quota page store' cache memory percent nor cache size was provided. Defaulting to 25% Heap Size
2011-04-20 15:46:48,007 INFO [storage.BDBQuotaStore] - Berkeley DB JE Disk Quota page store configured at /home/mickael/geoserver_data/gwc/diskquota_page_store
2011-04-20 15:46:48,010 INFO [storage.BDBQuotaStore] - Quota Store initialized. Global quota: 9.901MiB
2011-04-20 15:46:48,025 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2011-04-20 15:46:48,026 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller...
2011-04-20 15:46:48,027 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2011-04-20 15:46:48,094 INFO [diskquota.ConfigLoader] - Quota config is: /home/mickael/geoserver_data/gwc/geowebcache-diskquota.xml
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____a8 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____jc is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____pi is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____wa is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____06 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____bu is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____05 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____08 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____07 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____01 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____02 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,106 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____03 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____04 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____sm is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____wl is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____aa is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____rr is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:fra23_f10_____nw is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:testlmj is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:test2LMJ is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:r12 is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:testN is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer test:export is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,107 INFO [diskquota.ConfigLoader] - Configured quota for layer testNG is null. Discarding it to be attached to the global quota
2011-04-20 15:46:48,110 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2011-04-20 15:46:48,110 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2011-04-20 15:46:48,110 INFO [diskquota.DiskQuotaMonitor] - 10 layers attached to global quota 300.0MiB
2011-04-20 15:46:48,118 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2011-04-20 15:46:48,192 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 9 paths
2011-04-20 15:46:48,216 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2011-04-20 15:46:48,217 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2011-04-20 15:46:48,295 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
2011-04-20 15:47:37,030 WARN [geoserver.web] - Unable to find property: 'format.wms.application/vnd.google-earth.kmz xml' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,031 WARN [geoserver.web] - Unable to find property: 'format.wms.application/vnd.google-earth.kmz' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,032 WARN [geoserver.web] - Unable to find property: 'format.wms.kmz' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,033 WARN [geoserver.web] - Unable to find property: 'format.wms.openlayers' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,034 WARN [geoserver.web] - Unable to find property: 'format.wms.text/html' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,035 WARN [geoserver.web] - Unable to find property: 'format.wms.atom' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,036 WARN [geoserver.web] - Unable to find property: 'format.wms.application/atom xml' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,037 WARN [geoserver.web] - Unable to find property: 'format.wms.application/xml' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,038 WARN [geoserver.web] - Unable to find property: 'format.wms.image/svg' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:37,039 WARN [geoserver.web] - Unable to find property: 'format.wms.image/svg xml' for component: [class=org.geoserver.web.demo.MapPreviewPage]
2011-04-20 15:47:41,197 INFO [geoserver.wms] -
Request: getServiceInfo
2011-04-20 15:47:41,532 INFO [geoserver.wms] -
Request: getMap
Time = null
Filter = null
Format = application/openlayers
Buffer = 0
Height = 498
Width = 512
Tiled = false
Palette = null
SRS = EPSG:32632
Styles = [StyleImpl[ name=line]]
Legend = false
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Bbox = ReferencedEnvelope[7.346 : 58.505, 1.323 : 51.181]
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = NaN
FeatureId = null
RemoteOwsType = null
RemoteOwsURL = null
Sld = null
SldBody = null
StartIndex = null
ViewParams = {}
Crs = PROJCS["WGS 84 / UTM zone 32N",
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
PARAMETER["central_meridian", 9.0],
PARAMETER["scale_factor", 0.9996],
PARAMETER["false_easting", 500000.0],
UNIT["m", 1.0],
AXIS["Easting", EAST],
AXIS["Northing", NORTH],
AUTHORITY["EPSG","32632"]]
Env = {}
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = false
FeatureVersion = null
ValidateSchema = false
SldVersion = null
TilesOrigin = null
Filters = null
Exceptions = SE_XML
KMScore = 40
KMattr = true
Version = 1.1.0
Request = GetMap
RawKvp = {BBOX=7.346,1.323,58.505,51.181, VERSION=1.1.0, FORMAT=application/openlayers, SERVICE=WMS, HEIGHT=498, LAYERS=test:toto, REQUEST=GetMap, STYLES=, WIDTH=512, SRS=EPSG:32632}
Get = true
BaseUrl = http://172.17.100.10:8080/geoserver/
RequestCharset = UTF-8
