SDE raster catalog draws at certain extents but not when some pixels are outside of the entire dataset extent
Key: GEOS-4505
URL: http://jira.codehaus.org/browse/GEOS-4505
Project: GeoServer
Issue Type: Bug
Components: ArcSDE
Affects Versions: 2.0.1
Environment: Seen in both:
SDE 10 / Oracle Enterprise 11.2 / Linux Red Hat 5.5 (for DB and GeoServer) and
SDE 9.2 / Oracle 10.2 / Linux Debian Sarge (GeoServer) Linux Solaris (DB)
Reporter: Aleda Freeman
Assignee: Andrea Aime
Priority: Minor
Attachments: massgis_sde_raster_catalog_GISDATA.IMG_USGSQUAD_SGBASE.PNG
We have a layer massgis:GISDATA.IMG_USGSQUAD_SGBASE which is rendering an SDE-stored raster catalog. The raster catalog is a uint8, 256bit colormapped raster catalog. The layer draws fine at certain extents:
single tile image - this is the northeast part of MA, you can see several images in the catalog drawing together (see attached screenshot):
However, if I pan slightly to the east, thereby attempting to draw some pixels which are outside of the entire dataset extent, I get an error:
2011-04-22 15:49:46,090 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: org.vfny.geoserver.wms.WmsException: Rendering process failed
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:442)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.vfny.geoserver.wms.WmsException: Rendering process failed
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:412)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:421)
... 51 more
Caused by: java.lang.IllegalArgumentException: No registered TileDataFetcher for pixel type TYPE_8BIT_U and target type TYPE_16BIT_S
at org.geotools.arcsde.raster.io.TileDataFetcher.getTileDataFetcher(TileDataFetcher.java:84)
at org.geotools.arcsde.raster.io.NativeTileReader.<init>(NativeTileReader.java:195)
at org.geotools.arcsde.raster.io.TileReaderFactory.getInstance(TileReaderFactory.java:28)
at org.geotools.arcsde.raster.io.DefaultTiledRasterReader.read(DefaultTiledRasterReader.java:74)
at org.geotools.arcsde.raster.gce.ArcSDEGridCoverage2DReaderJAI.readAllTiledRasters(ArcSDEGridCoverage2DReaderJAI.java:306)
at org.geotools.arcsde.raster.gce.ArcSDEGridCoverage2DReaderJAI.read(ArcSDEGridCoverage2DReaderJAI.java:238)
at org.geotools.renderer.lite.StreamingRenderer.renderRaster(StreamingRenderer.java:2163)
at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:2046)
at org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:1987)
at org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1879)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1792)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:699)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1525)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1373)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:269)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:388)
... 52 more
