[Geoserver-devel] [jira] Created: (GEOS-4506) 'geoserver log output' WEBGUI-Page doesn't use log-location property from config page
                 Key: GEOS-4506
                 URL: http://jira.codehaus.org/browse/GEOS-4506
             Project: GeoServer
          Issue Type: Improvement
          Components: Configuration
         Environment: trunk
            Reporter: Rudi Hochmeister
            Assignee: Justin Deoliveira
            Priority: Trivial
Patch does following:
take geoserver log file location from Config as absolute path and only use if valid,
otherwise fallback to (geoserver-root)/logs/geoserver.log as default.
