[Geoserver-devel] [jira] Created: (GEOS-4509) Error Deleting CoverageStore, something has data file locked, requires complete GeoServer restart
                 Key: GEOS-4509
                 URL: http://jira.codehaus.org/browse/GEOS-4509
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-RC4
         Environment: 2.1 RC4, Tanuki 64-bit wrapper, Win7 Pro 64 bit, Java 6 Update 23 64-bit, PHP 5.3.1, also happens in my XP 32-bit environment and with all vs 2.x GeoServer.
            Reporter: John Castorina
            Assignee: Andrea Aime
            Priority: Critical
We use the REST api to create a new CoverageStore for each weather image that we create every 5 to 15 mins. That always works OK. We then use REST to purge old CoverageStores, typically after they are several hours old. After GeoServer has been running OK for about 8 hours, the DELETE CoverageStore fails (it works fine until then). When the DELETE fails, we use the REST "reload" command in an attempt to clear it. That is not successful (and we get the error described in GEOS-4481 if we try to look at it). The only method we have found so far that releases the locked file is to stop the GeoServer service then restart it. I am happy to provide more information or logs, but I do not know what you might need.
