GeoServer causes the exception: "java.lang.RuntimeException: Could not decode srs "EPSG:4326". Points of LinearRing do not form a closed linestring"
Key: GEOS-4510
URL: http://jira.codehaus.org/browse/GEOS-4510
Project: GeoServer
Issue Type: Bug
Components: PostGIS, WFS, WMS
Affects Versions: 2.1-RC4
Environment: FreeBSD 8.0, jdk 1.6.0, PostgreSQL 8.3.11, PostGIS 1.5.2, OpenLayers 2.10
Reporter: Konstantin
Assignee: Andrea Aime
There is an error requesting some vector features throught the WFS protocol.
The problem comes only with a big monitor resolution or when a page were zoomed out (ctrl+ScrollUp).
In other cases - there's no problem.
There is a vector layer with some big (more than 100 points each) polygons, that is taken from an SQL query to the DataBase.
SQL:
{quote}
SELECT mr.gid, mr.the_geom, r.nid, n.title
FROM map_russia mr
INNER JOIN region r ON mr.gid = r.gid
INNER JOIN node n ON r.nid = n.nid
{quote}
Projections in a layer options:
{quote}
Native SRS - EPSG:4326 (WGS 84)
Declared SRS - EPSG:4326 (WGS 84)
{quote}
OpenLayers requests this layer in an EPSG:3576 (EPSG:WGS 84 / North Pole LAEA Russia) projection throught the WFS protocol.
Request:
{code}
<wfs:GetFeature
xmlns:wfs="http://www.opengis.net/wfs"
service="WFS" version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Query typeName="kavmin:map_russia_query" srsName="EPSG:3576" xmlns:kavmin="http://localhost/kavmin">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:BBOX>
<ogc:PropertyName>the_geom</ogc:PropertyName>
<gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:3576">
<gml:lowerCorner>-12538187.538823 -8364362.983724</gml:lowerCorner>
<gml:upperCorner>13038187.538823 3630074.983724</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
{code}
The answer to request:
{code}
<ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows http://127.0.0.1:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.RuntimeException: Could not decode srs &apos;EPSG:4326&apos;
Points of LinearRing do not form a closed linestring</ows:ExceptionText>
<ows:ExceptionText>Details:</ows:ExceptionText>
<ows:ExceptionText>org.geoserver.platform.ServiceException: java.lang.RuntimeException: Could not decode srs 'EPSG:4326'
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1311)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:239)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.RuntimeException: Could not decode srs 'EPSG:4326'
at org.geoserver.feature.ReprojectingFilterVisitor.visit(ReprojectingFilterVisitor.java:121)
at org.geotools.filter.spatial.BBOXImpl.accept(BBOXImpl.java:204)
at org.geoserver.wfs.WFSReprojectionUtil.reprojectFilter(WFSReprojectionUtil.java:94)
at org.geoserver.wfs.WFSReprojectionUtil.normalizeFilterCRS(WFSReprojectionUtil.java:109)
at org.geoserver.wfs.GetFeature.toDataQuery(GetFeature.java:525)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:361)
at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:114)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy23.getFeature(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
... 114 more
Caused by: java.lang.IllegalArgumentException: Points of LinearRing do not form a closed linestring
at com.vividsolutions.jts.geom.LinearRing.validateConstruction(LinearRing.java:105)
at com.vividsolutions.jts.geom.LinearRing.<init>(LinearRing.java:100)
at com.vividsolutions.jts.geom.GeometryFactory.createLinearRing(GeometryFactory.java:339)
at com.vividsolutions.jts.geom.GeometryFactory.createLinearRing(GeometryFactory.java:329)
at org.geotools.filter.BBoxExpressionImpl.setBounds(BBoxExpressionImpl.java:90)
at org.geotools.filter.BBoxExpressionImpl.<init>(BBoxExpressionImpl.java:65)
at org.geotools.filter.FilterFactoryImpl.createBBoxExpression(FilterFactoryImpl.java:594)
at org.geotools.filter.FilterFactoryImpl.bbox(FilterFactoryImpl.java:304)
at org.geotools.filter.FilterFactoryImpl.bbox(FilterFactoryImpl.java:281)
at org.geoserver.feature.ReprojectingFilterVisitor.visit(ReprojectingFilterVisitor.java:119)
... 137 more
</ows:Exception>
</ows:ExceptionReport>
{code}
