RESTConfig worldimage upload fails
Key: GEOS-4529
URL: http://jira.codehaus.org/browse/GEOS-4529
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1.x
Reporter: David Winslow
Assignee: Andrea Aime
I am unable to upload a WorldImage file via RESTConfig and have it automatically configured. GeoServer gives an unhelpful NullPointerException when I do so.
Here is a curl command that produces the behavior I am seeing using the Pk50095 layer from the release dataset:
{code}
zip payload.zip Pk50095.* && curl 'http://admin:geoserver@anonymised.com:8080/geoserver/rest/workspaces/default/coveragestores/Pk90095/file.worldimage’ -v -T payload.zip -H 'Content-Type: application/zip'
{code}
