geoserver-printing: Specify the mapfish configuration file (config.yaml) per request
Key: GEOS-4531
URL: http://jira.codehaus.org/browse/GEOS-4531
Project: GeoServer
Issue Type: New Feature
Components: Community modules
Reporter: Bernhard Kiselka
Assignee: Andrea Aime
Attachments: geoserver-printing.patch_changeConfigPerRequest.diff
For printing completely different documents (not only varying by parameters, but by complete different page setup and blocks) it necessary to specify the mapfish configuration file with the print request.
At the client the parameter is set by adding an additional config: another_config_file.yaml to the optional property baseParams of GeoExt.data.PrintProvider.
Example:
var printProviderNoMap = new GeoExt.data.PrintProvider({
method: "POST", // necessary for big requests
capabilities: printCapabilities, // provide url instead for lazy loading
baseParams: {
config: "config_nomap.yaml"
This overrides the configuration of the initParameters property config from applicationContext.xml
Please review and integrate attached patch.
