[Geoserver-devel] [jira] Created: (GEOS-4533) wps-web process chaning bug
                 Key: GEOS-4533
                 URL: http://jira.codehaus.org/browse/GEOS-4533
             Project: GeoServer
          Issue Type: Bug
          Components: WPS
    Affects Versions: 2.1-RC3
         Environment: Installed on windows XP running server locally.
            Reporter: Syrus Mesdaghi
            Assignee: Andrea Aime
when creating a wps chain through wps-web, parameters may be dropped. There is a work around that I'll list as well. i've reproduced the problem with the existing JTS:buffer wps.
to reproduce, we'll take a point and buffer it 3 times. the bug shows up between the 1st and 3rd links of the chain.
1 - go to WPS builder and select the JTS:buffer wps.
2 - for its first parameter, select SUBPROCESS and then edit.
3 - for the first parameter of this SUBPROCESS, select SUBPROCESS again and edit
4 - we are now 3 levels deep. Use Point(10 10) for input and set the buffer distance to 1. fill in rest of the fields (I set quadrantSegments to 0 and capStyle to "round")
5 - click Apply to close the 1st link of the chain (3-level deep)
6 - now fill in the rest of the fields for the 2nd link of the chain but set distance to 2.
7 - now fill in the rest of the fields for the 3rd link of the chain but set distance to 3.
8 - if you try to execute this you will get the following error
================== Error
  <?xml version="1.0" encoding="UTF-8" ?>
- <ows:ExceptionReport version="1.1.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://localhost:8090/geoserver/schemas/ows/1.1.0/owsAll.xsd&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
- <ows:Exception exceptionCode="NoApplicableCode">
  <ows:ExceptionText>Unable to decode input: geom Process returned with an exception Parameter distance is missing but has min multiplicity &gt; 0</ows:ExceptionText>
  </ows:Exception>
  </ows:ExceptionReport>
================== Problem
if you click to generate the xml you will get the following that is **missing** distance of 2
<wps:Execute version="1.0.0" service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns="http://www.opengis.net/wps/1.0.0&quot; xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:wps="http://www.opengis.net/wps/1.0.0&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:wcs="http://www.opengis.net/wcs/1.1.1&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd&quot;&gt;
  <ows:Identifier>JTS:buffer</ows:Identifier>
  <wps:DataInputs>
    <wps:Input>
      <ows:Identifier>geom</ows:Identifier>
      <wps:Reference mimeType="text/xml; subtype=gml/3.1.1" xlink:href="http://geoserver/wps&quot; method="POST">
        <wps:Execute>
          <wps:DataInputs>
            <wps:Input>
                <wps:Execute>
                  <wps:DataInputs>
                    <wps:Input>
                      <wps:Data>
                        <wps:ComplexData mimeType="application/wkt"><![CDATA[POINT(10 10)]]></wps:ComplexData>
                      </wps:Data>
                    </wps:Input>
                    <wps:Input>
                      <ows:Identifier>distance</ows:Identifier>
                      <wps:Data>
                        <wps:LiteralData>1</wps:LiteralData>
                      </wps:Data>
                    </wps:Input>
                    <wps:Input>
                      <ows:Identifier>quadrantSegments</ows:Identifier>
                      <wps:Data>
                        <wps:LiteralData>0</wps:LiteralData>
                      </wps:Data>
                    </wps:Input>
                    <wps:Input>
                      <ows:Identifier>capStyle</ows:Identifier>
                      <wps:Data>
                        <wps:LiteralData>round</wps:LiteralData>
                      </wps:Data>
                    </wps:Input>
                  </wps:DataInputs>
                  <wps:ResponseForm>
                    <wps:RawDataOutput mimeType="application/wkt">
                      <ows:Identifier>result</ows:Identifier>
                    </wps:RawDataOutput>
                  </wps:ResponseForm>
                </wps:Execute>
              </wps:Reference>
            </wps:Input>
          </wps:DataInputs>
          <wps:ResponseForm>
            <wps:RawDataOutput mimeType="text/xml; subtype=gml/3.1.1">
          </wps:ResponseForm>
        </wps:Execute>
      </wps:Reference>
    </wps:Input>
    <wps:Input>
      <wps:Data>
        <wps:LiteralData>3</wps:LiteralData>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <wps:Data>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <wps:Data>
      </wps:Data>
    </wps:Input>
  </wps:DataInputs>
  <wps:ResponseForm>
  </wps:ResponseForm>
</wps:Execute>
=================== Workaround
there is a workaround: After step #2, not select SUBPROCESS again as mention in step #3 and just enter Point(10 10), fill in the rest and hit apply. now hit Edit to open the subprocess and then add the 3rd subprocess... following these steps, you can generate the following xml that is valid and runs as expected.
  <wps:DataInputs>
    <wps:Input>
        <wps:Execute>
          <wps:DataInputs>
            <wps:Input>
              <wps:Reference mimeType="application/wkt" xlink:href="http://geoserver/wps&quot; method="POST">
                <wps:Execute>
                  <wps:DataInputs>
                    <wps:Input>
                      <wps:Data>
                      </wps:Data>
                    </wps:Input>
                    <wps:Input>
                      <wps:Data>
                      </wps:Data>
                    </wps:Input>
                    <wps:Input>
                      <wps:Data>
                      </wps:Data>
                    </wps:Input>
                    <wps:Input>
                      <wps:Data>
                      </wps:Data>
                    </wps:Input>
                  </wps:DataInputs>
                  <wps:ResponseForm>
                  </wps:ResponseForm>
                </wps:Execute>
              </wps:Reference>
            </wps:Input>
            <wps:Input>
              <wps:Data>
                <wps:LiteralData>2</wps:LiteralData>
              </wps:Data>
            </wps:Input>
            <wps:Input>
              <wps:Data>
              </wps:Data>
            </wps:Input>
            <wps:Input>
              <wps:Data>
              </wps:Data>
            </wps:Input>
          </wps:DataInputs>
          <wps:ResponseForm>
          </wps:ResponseForm>
        </wps:Execute>
      </wps:Reference>
    </wps:Input>
    <wps:Input>
      <wps:Data>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <wps:Data>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <wps:Data>
      </wps:Data>
    </wps:Input>
  </wps:DataInputs>
  <wps:ResponseForm>
  </wps:ResponseForm>
</wps:Execute>
