[Geoserver-devel] [jira] Created: (GEOS-4536) teradata TeradataQueryBandFilter breaks geoserver-trunk-nightly build with compilation failure
                 Key: GEOS-4536
                 URL: http://jira.codehaus.org/browse/GEOS-4536
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.x
            Reporter: Ben Caradoc-Davies
            Assignee: Justin Deoliveira
            Priority: Blocker
             Fix For: 2.1.x
Justin, teradata TeradataQueryBandFilter added by you in r15783 does not compile. Looks like a trivial fix (remove the import); I'll try if I have time.
Because it uses -PcommunityRelease, this breaks the geoserver-trunk-nightly build.
{code}
[INFO] Building Teradata DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/target&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/teradata/src/main/java/org/geoserver/teradata/TeradataQueryBandFilter.java&gt;:\[15,41\] package com.sun.tools.hat.internal.server does not exist
{code}
