imagemap plugin fails with uncaught exception
Key: GEOS-4542
URL: http://jira.codehaus.org/browse/GEOS-4542
Project: GeoServer
Issue Type: Bug
Components: Imagemap
Affects Versions: 2.1-RC5
Reporter: Brian Youngblood
Assignee: Andrea Aime
Priority: Critical
When attempting to use the imagemap plugin, I get a uncaught exception on one of my layers. The same request is working with format=image/png just fine. I assume I have a point missing on one of my features that is causing it to fail. This request is using a WFS data store. Happy to give more information if needed, and retest if a fix is found. Maybe just a try/catch would work. Thanks. -brian
10 May 14:00:52 WARN [wms.map] - UNCAUGHT exception: null
10 May 14:00:52 ERROR [geoserver.ows] -
java.io.IOException: UNCAUGHT exception: null
at org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter$HTMLImageMapFeatureWriter.getPoint(HTMLImageMapWriter.java:567)
at org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter$PointWriter.writeGeometry(HTMLImageMapWriter.java:694)
at org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter$HTMLImageMapFeatureWriter.writeFeature(HTMLImageMapWriter.java:336)
at org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter.writeFeatures(HTMLImageMapWriter.java:190)
at org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap.writeLayers(EncodeHTMLImageMap.java:345)
at org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap.encode(EncodeHTMLImageMap.java:83)
at org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapResponse.write(HTMLImageMapResponse.java:43)
