GetCapabilities fails with Pk50095 layer
Key: GEOS-4544
URL: http://jira.codehaus.org/browse/GEOS-4544
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1-RC5
Environment: Mac OSX 10.6.7
Reporter: Andreas Hocevar
Assignee: Andrea Aime
The GetCapabilities response of a fresh 2.1-rc5 installation is invalid. It contains the following exception:
{noformat}
curl "http://localhost:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities"
<SRS>EPSG:62746405</SRS>
<SRS><?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException>
javax.xml.transform.TransformerException: Translator error
Translator error
Error occurred trying to write out metadata for layer: Pk50095
Unable to acquire a reader for this coverage with format: WorldImage
</ServiceException></ServiceExceptionReport>
{noformat}
So the response starts as a correct GetCapabilities doc, and terminates with an exception response embedded in the SRS list. When using the &tiled=true param, the behavior is different:
{noformat}
Translator error
{noformat}
In this case, the response is at least a valid exception document.
