Build failure in wps GridProcess caused by gt-grid API change
Key: GEOS-4547
URL: http://jira.codehaus.org/browse/GEOS-4547
Project: GeoServer
Issue Type: Bug
Components: WPS
Affects Versions: 2.2.x
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
{code}
-------- Original Message --------
Subject: Re: [jira] Issue Comment Edited: (GEOT-3577) Add line generation to vector grid module
Date: Wed, 11 May 2011 16:14:45 +0800
To: Caradoc-Davies, Ben (CESRE, Kensington) , geotools dev
On 11 May 2011 18:08, Ben Caradoc-Davies (JIRA) wrote:
The r37164 change just broke the GeoServer trunk build; Michael, I assume you will fix it?
Ah, well I"m afraid you assume wrong. Sorry.
The changes were committed to an unsupported module (grid) on trunk.
As I understand it, the policy with unsupported modules, but
especially those on trunk, is "user beware".
Since I'm neither a developer or user of GS I can't really help.
Michael
{code}
{code}
[INFO] Compiling 118 source files to /home/buildbot/GeoServerTrunkSlave/build with spaces/geoserver-trunk/src/extension/wps/wps-core/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/buildbot/GeoServerTrunkSlave/build with spaces/geoserver-trunk/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java:[18,25] cannot find symbol
symbol : class Element
/home/buildbot/GeoServerTrunkSlave/build with spaces/geoserver-trunk/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java:[113,35] cannot find symbol
location: class org.geoserver.wps.gs.GridProcess.GridFeatureBuilderImpl
/home/buildbot/GeoServerTrunkSlave/build with spaces/geoserver-trunk/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java:[128,34] cannot find symbol
/home/buildbot/GeoServerTrunkSlave/build with spaces/geoserver-trunk/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java:[131,40] cannot find symbol
symbol : method getCenter()
/home/buildbot/GeoServerTrunkSlave/build with spaces/geoserver-trunk/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/GridProcess.java:[132,40] cannot find symbol
{code}
