[Geoserver-devel] [jira] Created: (GEOS-4548) Migrating to Spring 3.0.5 and Spring Security 3.0.5
                 Key: GEOS-4548
                 URL: http://jira.codehaus.org/browse/GEOS-4548
             Project: GeoServer
          Issue Type: Improvement
          Components: Global
    Affects Versions: 2.2.x
            Reporter: Christian Mueller
            Assignee: Christian Mueller
             Fix For: 2.2.x
         Attachments: spring-3.0.5.patch
Attached is a patch for upgrading to Spring 3.0.5. Most of the modifications were necessary for Spring Security.
I tested with a fresh svn ceckout of geoserver, applied the patch and did a
mvn clean install -P allExtensions
The build was successful.
Geoserver running with spring 3.0.5 can be visited here
http://gis.linux4all.at/geoserver
The migration is needed for the new security features described here:
http://geoserver.org/display/GEOS/Enhancing+Geoserver+Authentication
