[Geoserver-devel] [jira] Created: (GEOS-4551) Avoid extra-read operation when read coverage is null. (RenderedImageMapOutputFormat)
                 Key: GEOS-4551
                 URL: http://jira.codehaus.org/browse/GEOS-4551
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.0
            Reporter: Daniele Romagnoli
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 2.1.1
The method org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage
has at line 1284 an extra-read operation.
Basically, it does a read operation. Then, if the returned coverage is null, it does another read operation with a reduced set of parameter.
I think this could be slightly improved by avoiding that when this isn't really needed.
