Build failure with Maven 2.2
Key: GEOS-4552
URL: http://jira.codehaus.org/browse/GEOS-4552
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 2.2.x
Environment: Linux/Maven 2.2
Reporter: Tisham Dhar
Assignee: Justin Deoliveira
Priority: Minor
The configuration project is failing to build with the following error:
[INFO] Error for project: Configuration Deployment PlugIn (during install)
[INFO] The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
My maven version is:
Apache Maven 2.2.1 (rdebian-4)
Java version: 1.6.0_22
Java home: /usr/lib/jvm/java-6-openjdk/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux" version: "2.6.38-8-generic" arch: "amd64" Family: "unix"
Running on Ubuntu Natty
