[Geoserver-devel] [jira] Created: (GEOS-4561) Failure in geoserver-trunk-nightly community/ftp caused by PageAuthorizer removal
                 Key: GEOS-4561
                 URL: http://jira.codehaus.org/browse/GEOS-4561
             Project: GeoServer
          Issue Type: Bug
          Components: Community modules
    Affects Versions: 2.2.x
            Reporter: Ben Caradoc-Davies
            Assignee: Christian Mueller
Christian, your changes in r15861 "Remove deprecated PageAuthorizer" (and possibly r15857 "Remove Spring Security deprecations") caused the geoserver-trunk-nightly community/ftp build to fail. geoserver-trunk-nightly includes -PcommunityRelease, which enables this module. There are some Spring security problems in there too.
{code}
[INFO] Building GeoServer Embedded FTP server
[INFO] Deleting directory /home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/target
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting /home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 10 source files to /home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[26,36] package org.springframework.security does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[27,36] package org.springframework.security does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[28,46] package org.springframework.security.providers does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[29,48] package org.springframework.security.userdetails does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[65,12] cannot find symbol
symbol : class AuthenticationManager
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[71,41] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[19,36] package org.springframework.security does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[20,48] package org.springframework.security.userdetails does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[9,48] package org.springframework.security.userdetails does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[37,12] cannot find symbol
symbol : class UserDetails
location: class org.geoserver.ftp.FtpLetCallBackAdapter
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[38,33] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[54,31] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[71,33] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[87,31] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[104,35] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[120,33] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[137,36] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[153,34] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[170,34] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[186,32] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[203,33] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[219,31] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[240,33] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FTPCallback.java:[258,31] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[11,48] package org.springframework.security.userdetails does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[27,40] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[37,38] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[47,40] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[57,38] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[67,42] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[77,40] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[87,43] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[97,41] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[107,41] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[117,39] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[127,40] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[137,38] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[147,40] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java:[158,38] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[92,36] package org.springframework.security does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[92,65] cannot find symbol
symbol : class UsernamePasswordAuthenticationToken
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[96,45] package org.springframework.security does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/GSFTPUserManager.java:[121,17] cannot find symbol
symbol : class GrantedAuthority
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[41,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[41,45] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[45,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[45,78] package org.springframework.security.userdetails does not exist
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[60,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[74,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[88,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[102,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[116,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[130,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[144,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[158,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[172,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[186,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[200,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[214,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[233,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[253,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[267,8] cannot find symbol
/home/tomcat/.hudson/jobs/geoserver-trunk-nightly/workspace/geoserver_trunk/src/community/ftp/src/main/java/org/geoserver/ftp/FtpLetCallBackAdapter.java:[283,8] cannot find symbol
{code}
