Mapfish pdf print module update with proxy url reading
Key: GEOS-4574
URL: http://jira.codehaus.org/browse/GEOS-4574
Project: GeoServer
Issue Type: Improvement
Environment: Debian 6, Tomcat 6, Geonode
Reporter: Giulia Bruno
Assignee: Andrea Aime
Priority: Minor
Attachments: mapfish_ithaca.patch
The java class MapPrinterServlet.java has been modified to read the proxy url by means of the findProxyUrl() function.
Function findProxyUrl() changes the basePath if a proxy is set.
If present, the proxy url is set in the file global.xml in the data directory of geoserver. The path to data directory can be:
(1) find in the environment variable GEOSERVER_DATA_DIR;
(2) find in the file web.xml in the directory geoserver/WEB-INF/web.xml (as context-param node element) (3) the default directory path: geoserver/data
In the global.xml file, the proxy url is defined in the proxyBaseUrl node element.
We need help for having an OS-independent solutions in searching the path of the data directory, since paths and current directories depend on the OS. By now, the solution exploits an absolute path, working for our application.
