[Geoserver-devel] [jira] Created: (GEOS-4576) Improve checks to avoid DirectRasterRender Path in case there is a transformation in the rasterSymbolizer
                 Key: GEOS-4576
                 URL: http://jira.codehaus.org/browse/GEOS-4576
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.0, 2.2.x
            Reporter: Daniele Romagnoli
            Assignee: Andrea Aime
Whilst playing with RenderingTransformation I have noticed that in case the style contains a transformation applied on a raster to produce a raster (therefore, a RasterSymbolizer is in the style), the DirectRasterRender path is applied and no transformations are applied.
We should improve the checks performed (as an instance, by checking for the presence of any transformation in the style) to choose whether to perform direct raster path or not.
