"Force declared srs" does not work for rasters
Key: GEOS-4583
URL: http://jira.codehaus.org/browse/GEOS-4583
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1.0
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.1.1
Despite the good intentions of trying to pass the declared CRS in the hints the approach does not work because both during startup and new configuration the pool generates the reader once without the hints (because the hints come from the layer, that still does not exist/is still unread from the disk) and then cached without taking the hints into account.
I'm going to make a new reader cache that takes into account hints as well for keying, according to my tests that works (tested manually, will have to add a integration test for the build as well)
