[Geoserver-devel] [jira] Created: (GEOS-4591) WCS 1.1.1 XML GetCoverage wtih SDE datastore produces ParameterNotFoundException
                 Key: GEOS-4591
                 URL: http://jira.codehaus.org/browse/GEOS-4591
             Project: GeoServer
          Issue Type: Bug
          Components: ArcSDE
    Affects Versions: 2.1.0
         Environment: Oracle 11.2, SDE 10 - also Oracle 10.2, SDE 9.2 with GeoServer 2.0.3
            Reporter: Aleda Freeman
            Assignee: Andrea Aime
A GetCoverage XML request for 1.1.1 works against a GeoTiff datastore, but not an SDE data store.
This is with a 2.1 nightly I downloaded 5/27.
The 1.1.1 request (it works OK for 1.0.0 regardless of datastore type) is:
<GetCoverage version="1.1.1" service="WCS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns="http://www.opengis.net/wcs/1.1.1&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xsi:schemaLocation="http://www.opengis.net/wcs/1.1.1 http://schemas.opengis.net/wcs/1.1.1/wcsAll.xsd&quot;&gt;
  <ows:Identifier>massgis:GISDATA.IMG_COQ2001</ows:Identifier>
  <DomainSubset>
    <ows:BoundingBox crs="urn:ogc:def:crs:EPSG::26986">
      <ows:LowerCorner>249986.0 875774.0</ows:LowerCorner>
      <ows:UpperCorner>250155.0 875938.0</ows:UpperCorner>
    </ows:BoundingBox>
  </DomainSubset>
  <Output store="true" format="image/png">
    <GridCRS>
      <GridBaseCRS>urn:ogc:def:crs:EPSG::26986</GridBaseCRS>
      <GridType>urn:ogc:def:method:WCS:1.1:2dSimpleGrid</GridType>
      <GridOffsets>0.30017761989342806 -0.30036630036630035</GridOffsets>
      <GridCS>urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS</GridCS>
    </GridCRS>
  </Output>
</GetCoverage>
The error we get is:
<ows:ExceptionReport version="1.1.0"
  xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://maps.massgis.state.ma.us/geoserver/schemas/ows/1.1.0/owsAll.xsd&quot;
  xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>org.opengis.parameter.ParameterNotFoundException: Parameter is mandatory and shall provide the extent and dimension to request
Parameter is mandatory and shall provide the extent and dimension to request</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Gabriel Roldan says 6/1/11: "Looks like a false expectation on the sde plugin for a grid parameter"
