[Geoserver-devel] [jira] Created: (GEOS-4594) PDF map output of very small size will fail to be generated using the partial buffer strategy
                 Key: GEOS-4594
                 URL: http://jira.codehaus.org/browse/GEOS-4594
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.1.1
We have to close the pdf generator, that unfortunately also closes the stream it's built on, as a result close() is called on the partial buffer output stream, which fails to flush the buffer if we are still working against the in memory buffer.
