[Geoserver-devel] [jira] Created: (GEOS-4601) Point Symbolizer ExternalGraphic rendering problem
                 Key: GEOS-4601
                 URL: http://jira.codehaus.org/browse/GEOS-4601
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.0, 2.1-RC5
         Environment: Windows Server 2003
            Reporter: Mark Logan
            Assignee: Andrea Aime
         Attachments: extgraphic-issue.png
Rendering ExternalGraphic in a point symbolizer causes the graphic to have some degree of resizing causing blurring even when the size of the image (height) is not specified - as stated in documentation. This was not an issue in version 2.0.2 which we had been using until we upgraded. This effect seems to be exhibited
with any graphic used and is most easily seen with simple graphics (see attachment)
  <PointSymbolizer>
            <Graphic>
              <ExternalGraphic>
                <OnlineResource
                  xlink:type="simple"
                  xlink:href="http://www.geopii.com/planning/icons/blur-check.png&quot; />
                <Format>image/png</Format>
              </ExternalGraphic>
            </Graphic>
          </PointSymbolizer>
This has been tested with jpeg, gif, png (8/24bit)
