[Geoserver-devel] [jira] Created: (GEOS-4605) SLD requests are not advertized for WMS 1.3
                 Key: GEOS-4605
                 URL: http://jira.codehaus.org/browse/GEOS-4605
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.2.x
            Reporter: Bart van den Eijnden
            Assignee: Andrea Aime
             Fix For: 2.2.x
Currently the SLD requests such as DescribeLayer are not advertized in the GetCapabilities by GeoServer when using WMS 1.3.
This should be done in the following way:
http://schemas.opengis.net/sld/1.1.0/example_capabilities.xml
so using the following schema extension for the GetCapabilities:
http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd
