[Geoserver-devel] [jira] Created: (GEOS-4607) Extended the scale line so that you can choose if you want to show the borders of the rectangle and which unit you want.
                 Key: GEOS-4607
                 URL: http://jira.codehaus.org/browse/GEOS-4607
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
    Affects Versions: 2.1.0
            Reporter: Torbjørn Danielsen
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: ScaleLineDecoration.java
Re-factored the ScaleLineDecoration class so that the line drawings and the text drawing for the scale line could be extracted into a separate method for better readability.
Added two options:
  * border - Boolean. If set to false removes the border around the scale line
  * unit - String. If set to "metric" shows only the metric unit and if set to "imperial" shows only imperial unit, defaults to both.
The class will behave as before if none of the options is set. In other words default behavior is with border and both units showing.
