[Geoserver-devel] [jira] Created: (GEOS-4610) FileWatcher.java does not recognize restored files
                 Key: GEOS-4610
                 URL: http://jira.codehaus.org/browse/GEOS-4610
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 2.2.x
            Reporter: Christian Mueller
            Assignee: Christian Mueller
            Priority: Minor
             Fix For: 2.2.x
FileWatcher.java
Method:
     public boolean isModified() {
         long now = System.currentTimeMillis();
         if((now - lastCheck) > 1000) {
             lastCheck = now;
             stale = file.exists() && (file.lastModified() > lastModified);
         return stale;
A file is recognized as modified if the last modified timestamp is newer as the last known timestamp. In case of restoring a file with a backup/restore utility, the timestamp could be older. Replacing > with != gives
stale = file.exists() && (file.lastModified() != lastModified);
This will do the job.
