[Geoserver-devel] [jira] Created: (GEOS-4611) Avoid unnecessary reloads caused by FileWatcher
                 Key: GEOS-4611
                 URL: http://jira.codehaus.org/browse/GEOS-4611
             Project: GeoServer
          Issue Type: Improvement
          Components: Global
    Affects Versions: 2.2.x
            Reporter: Christian Mueller
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 2.2.x
         Attachments: filewatcher.patch
Attached a patch adding a method for setting the last modified time stamp.
Note: Since there is only one method added, no problems will occur. A test case will be added during my GSoc 2011 project.
