[Geoserver-devel] [jira] Created: (GEOS-4619) Build failure in web and wcs1_1 caused by stale gt-temporal dependency
                 Key: GEOS-4619
                 URL: http://jira.codehaus.org/browse/GEOS-4619
             Project: GeoServer
          Issue Type: Bug
          Components: UI, WCS
    Affects Versions: 2.2.x
            Reporter: Ben Caradoc-Davies
            Assignee: Ben Caradoc-Davies
            Priority: Blocker
             Fix For: 2.2.x
gt-temporal was merged into gt-main (and other core libraries). It no longer exists. GeoServer web and wcs1_1 modules still depended on it. I noticed this when I purged by local maven repo of GeoTools artifacts and built GeoTools and the GeoServer offline: the build failed because of the missing dependency. We have been shipping this stale chunk of code; the implementation that gets run is a classpath lucky dip that could cause inexplicable runtime failures.
The solution is remove the stale gt-temporal dependency. Test build underway.
