Build failure in wms_1_1_1 DimensionsRasterGetFeatureInfoTest
Key: GEOS-4621
URL: http://jira.codehaus.org/browse/GEOS-4621
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.2.x
Environment: Apache Maven 2.2.1 (r801777; 2009-08-07 03:16:01+0800)
Java version: 1.5.0_22
Java home: /home/car605/junk/java/jdk1.5.0_22.i586/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux" version: "2.6.35.13-92.fc14.x86_64" arch: "i386" Family: "unix"
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
Priority: Blocker
Fix For: 2.2.x
Passes on OpenGeo Hudson. Fails on our buildbot, and locally in Maven and Eclipse. All platforms are JDK 1.5.0_22 i586 without JAI installed.
{noformat}
Failed tests:
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
Tests run: 333, Failures: 1, Errors: 0, Skipped: 0
{noformat}
{noformat}
Test set: org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest
Tests run: 5, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.467 sec <<< FAILURE!
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest) Time elapsed: 1.47 sec <<< FAILURE!
junit.framework.AssertionFailedError: expected:<14.51> but was:<14.591999743133783>
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.failNotEquals(Assert.java:280)
at junit.framework.Assert.assertEquals(Assert.java:98)
at junit.framework.Assert.assertEquals(Assert.java:105)
at org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest.testNoDimension(DimensionsRasterGetFeatureInfoTest.java:63)
{noformat}
