[Geoserver-devel] [jira] Created: (GEOS-4622) Build failure in community/python breaks geoserver-trunk-nightly
                 Key: GEOS-4622
                 URL: http://jira.codehaus.org/browse/GEOS-4622
             Project: GeoServer
          Issue Type: Bug
          Components: Community modules
    Affects Versions: 2.2.x
         Environment: OpenGeo Hudson
            Reporter: Ben Caradoc-Davies
            Assignee: Justin Deoliveira
            Priority: Blocker
             Fix For: 2.2.x
{noformat}
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/src/main/java/org/geoserver/python/format/PythonVectorGetMapOutputFormat.java&gt;:\[12,7\] org.geoserver.python.format.PythonVectorGetMapOutputFormat is not abstract and does not override abstract method getCapabilities(java.lang.String) in org.geoserver.wms.GetMapOutputFormat
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/src/main/java/org/geoserver/python/format/PythonGetMapOutputFormat.java&gt;:\[13,7\] org.geoserver.python.format.PythonGetMapOutputFormat is not abstract and does not override abstract method getCapabilities(java.lang.String) in org.geoserver.wms.GetMapOutputFormat
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/python/src/main/java/org/geoserver/python/format/PythonMapGetMapOutputFormat.java&gt;:\[13,7\] org.geoserver.python.format.PythonMapGetMapOutputFormat is not abstract and does not override abstract method getCapabilities(java.lang.String) in org.geoserver.wms.GetMapOutputFormat
{noformat}
