[Geoserver-devel] [jira] Created: (GEOS-463) Create a navigator bar for exported wiki docs
         Key: GEOS-463
         URL: http://jira.codehaus.org/browse/GEOS-463
     Project: GeoServer
        Type: Sub-task
  Components: Documentation
    Versions: 1.3.0 RC6
    Reporter: Chris Holmes
Assigned to: Brent Owens
    Priority: Critical
     Fix For: 1.3.0 RC7
When the docs are exported as html currently they are all just flat. We should have a sidebar to assist with navigating through them. It looks like you may be able to set this up in JIRA, with the Space Admin -> Space Export Layout option. But it needs to be investigated, to see if it actually works. If it doesn't then doc some instructions on how you go about doing it, and put the navigator box thing somewhere in svn.
For more information on JIRA, see:
