app-schema support for resource publishing split
Key: GEOS-4641
URL: https://jira.codehaus.org/browse/GEOS-4641
Project: GeoServer
Issue Type: Sub-task
Components: Application schema
Affects Versions: 2.2.x
Reporter: Ben Caradoc-Davies
Assignee: Ben Caradoc-Davies
app-schema uses a single repository of DataAccess instances that permits each feature type to be defined once. Once the resource/publishing split is implemented, app-schema will need to maintain a separate repository for each profile, so that each profile can have its distinct definitions of feature types and the relationships between them. Feature chaining will have to resolve references to nested feature types in the repository for the profile from which the top-level feature type was obtained.
