[Geoserver-devel] [jira] Created: (GEOS-4644) Build failure in wcs1_0 GetCoverageTest testElevation{First, Second}
Build failure in wcs1_0 GetCoverageTest testElevation{First,Second}
                 Key: GEOS-4644
                 URL: https://jira.codehaus.org/browse/GEOS-4644
             Project: GeoServer
          Issue Type: Bug
          Components: WCS
    Affects Versions: 2.2.x
         Environment: Apache Maven 2.2.1 (r801777; 2009-08-07 03:16:01+0800)
Java version: 1.6.0_24
Java home: /usr/lib/jvm/java-6-sun-1.6.0.24/jre
Default locale: en_AU, platform encoding: UTF-8
OS name: "linux" version: "2.6.32-5-686" arch: "i386" Family: "unix"
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Blocker
Passes on Hudson. Fails on our buildbot.
Might this numerical difference be the consequence of filesystem order influencing layer order, as in GEOS-4621?
{noformat}
Test set: org.geoserver.wcs.GetCoverageTest
Tests run: 13, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 2.021 sec <<< FAILURE!
testElevationFirst(org.geoserver.wcs.GetCoverageTest) Time elapsed: 0.114 sec <<< FAILURE!
junit.framework.AssertionFailedError: expected:<18.2849999185419> but was:<18.26599991763942>
  at junit.framework.Assert.fail(Assert.java:47)
  at junit.framework.Assert.failNotEquals(Assert.java:280)
  at junit.framework.Assert.assertEquals(Assert.java:98)
  at junit.framework.Assert.assertEquals(Assert.java:105)
  at org.geoserver.wcs.GetCoverageTest.checkTimeCurrent(GetCoverageTest.java:392)
  at org.geoserver.wcs.GetCoverageTest.testElevationFirst(GetCoverageTest.java:416)
testElevationSecond(org.geoserver.wcs.GetCoverageTest) Time elapsed: 0.084 sec <<< FAILURE!
junit.framework.AssertionFailedError: expected:<13.337999683572> but was:<13.356999684474431>
  at org.geoserver.wcs.GetCoverageTest.testElevationSecond(GetCoverageTest.java:446)
{noformat}
