[Geoserver-devel] [jira] Created: (GEOS-4648) GWC tilesets should filter out layer without a geometry
                 Key: GEOS-4648
                 URL: https://jira.codehaus.org/browse/GEOS-4648
             Project: GeoServer
          Issue Type: Bug
          Components: GWC
    Affects Versions: 2.1.0
            Reporter: Bart van den Eijnden
            Assignee: Andrea Aime
Something I noticed with the embedded GWC: if you have a feature type in GeoServer without a geometry, GeoServer WMS does not advertize it as a layer in the GetCapabilities. However, when using tiled true, GWC will give back tilesets for this layer.
Should it not use the same logic as GeoServer WMS and not advertize tilesets for layers without a geometry? Yes, it should.
Gabriel Roldán reopened BugGEOS-4648
GWC should filter out layer without a geometry
Change By:
Gabriel Roldán (26/Oct/12 2:35 PM)
Status:
Resolved Reopened
Resolution:
Fixed
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
