GWC Reload Configuration broken
Key: GEOS-4650
URL: https://jira.codehaus.org/browse/GEOS-4650
Project: GeoServer
Issue Type: Bug
Components: GWC
Affects Versions: 2.1.1
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Email report:
Is anyone able to Reload Configuration (via the button on the GWC demo page) in the GWC that's embedded with GeoServer? When I do it, I get a blank browser screen (no Firebug on console errors), and when I reload the GWC demo page, I get a 400: null.
Nothing in the logs. Restarting the Suite outright makes GWC happy again. Before I file a ticket, I wanted to know if anyone else can reproduce this (easy enough to click the button and see). It could be related to the custom geowebcache.xml file I'm working on, although that seems to be working fine...
Just fired up 2.4.3, went to GWC demo page, clicked the reload button at the bottom. got prompted for GS admin credentials, and then got this response:
Unknown or malformed request. Please try again, somtimes the form is not properly received. This frequently happens on the first POST after a restart. The POST was to /geoserver/gwc/rest/reload
And, as you might expect, the same from
$ curl -u admin:geoserver -d reload_configuration=1 http://localhost:8080/geoserver/gwc/rest/reload
[ https://jira.codehaus.org/browse/GEOS-4650?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Gabriel Roldán reopened GEOS-4650:
reopening as the form field gets empty to ReloadServlet in some cases like curl -d ...
Key: GEOS-4650
Project: GeoServer
Issue Type: Bug
Components: GWC
Fix For: 2.1.x
Email report:
