[Geoserver-devel] [jira] Created: (GEOS-4651) GetFeatureInfo + GML output + click on a empty area = service exception
                 Key: GEOS-4651
                 URL: https://jira.codehaus.org/browse/GEOS-4651
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.1.2
As the summary says, when trying to encode collection bounds GetFeatureInfo with GML format will throw a service exception with the following trace:
{code}
Caused by: java.lang.NullPointerException
       at org.geotools.gml.producer.GeometryTransformer$GeometryTranslator.encode(GeometryTransformer.java:158)
       at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.writeBounds(FeatureTransformer.java:665)
       at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:506)
       at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
       at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
       at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
       at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
       ... 52 more
{code}
The code cannot handle the empty array of feature collections it is asked to encode properly and will throw this exception.
