[Geoserver-devel] [jira] Created: (GEOS-4652) Support building GeoServer with Maven 3
                 Key: GEOS-4652
                 URL: https://jira.codehaus.org/browse/GEOS-4652
             Project: GeoServer
          Issue Type: Improvement
          Components: Global
    Affects Versions: 2.2.x
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
             Fix For: 2.2.x
Add support for building GeoServer with Maven 3.
Build currently fails in maven/config with:
{noformat}
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-plugin-plugin:2.7:descriptor (default-descriptor) on project config: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match. org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V -> [Help 1]
{noformat}
