GetLegendGraphic urls in WMS GetCapabilities miss STYLE parameter
Key: GEOS-4661
URL: https://jira.codehaus.org/browse/GEOS-4661
Project: GeoServer
Issue Type: Bug
Components: WMS
Reporter: Bart van den Eijnden
Assignee: Andrea Aime
INSPIRE demands a named style called inspire_common:DEFAULT, which needs to be simple black lines etc. This makes it likely that people will need to set up multiple styles for a layer, also a more meaningful style.
However, the LegendURL advertized in the GeoServer WMS GetCapabilities response does not output the STYLE parameter, so all legends will show up with the default style. It should be sufficient to add the STYLE parameter to the advertized LegendURL.
