[Geoserver-devel] [jira] Created: (GEOS-4670) Geoserver does npt display any layer from SQL Server 2008
                 Key: GEOS-4670
                 URL: https://jira.codehaus.org/browse/GEOS-4670
             Project: GeoServer
          Issue Type: Bug
          Components: SQLServer
    Affects Versions: 2.1.1
         Environment: Windows , Geoserver 2.1.1
            Reporter: KrishnaT
            Assignee: Andrea Aime
I get the following error when I try review the layer
06 Jul 15:20:04 ERROR [geoserver.ows] -
INFO | jvm 1 | 2011/07/06 15:20:04 | org.geoserver.platform.ServiceException: Rendering process failed
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:473)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:208)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.GetMap.run(GetMap.java:379)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.GetMap.run(GetMap.java:107)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:352)
INFO | jvm 1 | 2011/07/06 15:20:04 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2011/07/06 15:20:04 | at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
INFO | jvm 1 | 2011/07/06 15:20:04 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
INFO | jvm 1 | 2011/07/06 15:20:04 | at java.lang.reflect.Method.invoke(Method.java:597)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:51)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:33)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
INFO | jvm 1 | 2011/07/06 15:20:04 | at $Proxy26.getMap(Unknown Source)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
INFO | jvm 1 | 2011/07/06 15:20:04 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
INFO | jvm 1 | 2011/07/06 15:20:04 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.Server.handle(Server.java:324)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
INFO | jvm 1 | 2011/07/06 15:20:04 | Caused by: java.lang.NullPointerException
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1894)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:773)
INFO | jvm 1 | 2011/07/06 15:20:04 | at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:447)
INFO | jvm 1 | 2011/07/06 15:20:04 | ... 87 more
INFO | jvm 1 | 2011/07/06 15:20:05 | 06 Jul 15:20:05 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
