[Geoserver-devel] [jira] Created: (GEOS-4675) Mosaics/Pyramids broken under WMS 1.3.0
                 Key: GEOS-4675
                 URL: https://jira.codehaus.org/browse/GEOS-4675
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.x
         Environment: Java(TM) SE Runtime Environment (build 1.6.0_24-b07)
Java HotSpot(TM) 64-Bit Server VM (build 19.1-b02, mixed mode)
Ubuntu Linux 10.10 (Maverick)
            Reporter: Robert Coup
            Assignee: Andrea Aime
Steps to reproduce:
1. Create a mosaic using the zip from http://dl.dropbox.com/u/726114/mosaic.zip
2. Publish it. The CRS (native + declared) should be detected and shown as EPSG:2193. I created the layer as {{r:mosaic}}
3. WMS 1.1 request works great:
{code}
http://localhost:8001/geoserver/r/wms?service=WMS&version=1.1.1&request=GetMap&layers=r:mosaic&styles=&bbox=1587997.884,6162000.451,1612003.226,6198002.116&width=341&height=512&srs=EPSG:2193&format=image/png
{code}
4. WMS 1.3 request (swapped &bbox= X&Y order, use &crs= instead of &srs=):
{code}
http://localhost:8001/geoserver/r/wms?service=WMS&version=1.3.0&request=GetMap&layers=r:mosaic&styles=&bbox=6162000.451,1587997.884,6198002.116,1612003.226&width=341&height=512&crs=EPSG:2193&format=image/png
07 Jul 14:55:38 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:291)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:207)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:1)
  at org.geoserver.wms.GetMap.run(GetMap.java:379)
  at org.geoserver.wms.GetMap.run(GetMap.java:107)
  at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:352)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:60)
  at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:1)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:56)
  at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:1)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy23.getMap(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
  at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
  at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
  at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
  at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
  at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
  at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.geoserver.platform.ServiceException: java.lang.UnsupportedOperationException: This affine transform is unmodifiable.
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:870)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:289)
  ... 88 more
Caused by: java.lang.UnsupportedOperationException: This affine transform is unmodifiable.
  at org.geotools.referencing.operation.matrix.XAffineTransform.checkPermission(XAffineTransform.java:88)
  at org.geotools.referencing.operation.transform.AffineTransform2D.checkPermission(AffineTransform2D.java:94)
  at org.geotools.referencing.operation.matrix.XAffineTransform.preConcatenate(XAffineTransform.java:225)
  at org.geotools.gce.imagemosaic.RasterLayerRequest.inspectCoordinateReferenceSystems(RasterLayerRequest.java:779)
  at org.geotools.gce.imagemosaic.RasterLayerRequest.computeRequestSpatialElements(RasterLayerRequest.java:969)
  at org.geotools.gce.imagemosaic.RasterLayerRequest.prepare(RasterLayerRequest.java:748)
  at org.geotools.gce.imagemosaic.RasterLayerRequest.<init>(RasterLayerRequest.java:241)
  at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:330)
  at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:625)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1252)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:818)
  ... 89 more
{code}
However, a GeoTIFF layer built off exactly the same map tile & projection (ie. no mosaic) works fine with both requests. An image pyramid fails with the same error.
