[Geoserver-devel] [jira] Created: (GEOS-4677) Expose the "reset" command via rest-config as well
                 Key: GEOS-4677
                 URL: https://jira.codehaus.org/browse/GEOS-4677
             Project: GeoServer
          Issue Type: Improvement
          Components: REST
    Affects Versions: 2.1.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.1.2
The data or metadata in some store might have changed via means other than rest-config itself (e.g., the mosaic index contents which might be stored in a database), in that case we need to reset the configuration to force the stores to be reloaded.
Should be easy to add, just use the same code as the GUI
