[Geoserver-devel] [jira] Created: (GEOS-47) UerContainer based login/logout needed
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-47
Here is an overview of the issue:
        Key: GEOS-47
    Summary: UerContainer based login/logout needed
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: 6 hours
Time Spent: Unknown
  Remaining: 6 hours
    Project: GeoServer
Components:
             Struts
   Fix Fors:
             1.2
   Versions:
             1.2
   Assignee: Richard Gould
   Reporter: Jody Garnett
    Created: Fri, 16 Jan 2004 5:30 PM
    Updated: Fri, 16 Jan 2004 5:30 PM
Environment: struts/config
Description:
UserContainer is used on the recomendation of the oreilly struts book as a strongly typed persession container managed by login/logout actions.
If they don't have a usercontainer in session they are not logged in.
Right now we store the "Selected DataStoreID" for example in Session. We should move this to UserCOntainer and set up the login/logout actions.
Right now the application configuration is open to all (this is a bad thing).
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
